Tractor overheated the other day. Build up of grass behind screen. Blew everything out with air compressor, topped off coolant. Runs now without overheating, but something is not right.
If I drive at full throttle (PTO disengaged) after 20 seconds or so it bogs down and starts to die.
If I mow at full throttle (PTO engaged) after 2-3 seconds or so it bogs down and starts to die.
If I back the throttle off a bit (in either scenario) it seems to work ok, occasional stumble. Seems like maybe starving for fuel.
Replaced fuel filter between tank and fuel pump yesterday. Replaced fuel filter in canister at engine last year (only a couple dozen hours ago). Air filter is clean, blew it out with air compressor just for fun.
What should I be looking at?
