G3200 Crown and Pinion help
tractorfixr
Kamloops BC Canada
Im new to the chat. Im looking for a crown and pinion set for a G3200 garden tractor. There is no part number in the Kubota system, wondering if anyone can help me. The reason for the failure is the owner ( not Me ) decided to mount a 500 lb block as a counterweight when using the loader
dlundblad
G5200, L2501, ZD1211
May 16, 2009
504
IN
Did you try Messicks? Do a search under differential. You need an account to view diagrams.
Not really following what the tractor is.. It has a loader?
9,139
I can't tell you if the parts are actually available.
And you will need to verify fitment per serial number.
But in this case your better of if available to replace the whole assembly, which includes the ring and pinion.
P/N 66021-81492 @ ~$299.36
Ring and pinion set is:
P/N 66021-81472 @ ~$545.17
dlundblad
May 16, 2009
504
IN
At those prices, one might be better off looking for a used rear end, but keep in mind the G3200 is gear drive so HST parts may not be compatible.
BruceP
G5200H
Aug 7, 2016
852
371
Richmond, Vermont, USA
I own G4200 HST so have some knowledge with this line of garden tractors. I find it difficult to believe that anyone could 'break' the rear-end on one of these things. The thing is built like a tank. for a garden-tractor, the rear-end is WAYYYY overbuilt. (the chincy steering-gear is another thing)
The G3200 was available in BOTH 'geared' and HST versions.... the OP did not say which his tractor is.
In any case, there are often complete used rear-ends for our tractors available on eBay. I would expect the cost would be reasonable... but shipping may be an issue unless you could find one within driving-distance.
SidecarFlip
Banned
558
When you run anything that requires lubricating fluid dry, it's going to fail sooner or later, probably sooner.:)
