G2000 (Gas) Idle Speed too fast
summergs1
G2000-S
Apr 11, 2016
Marriottsville, MD
Help! The idle speed on my G2000S is way too high...I would say 1100-1200rpm.
There are two adjustment screws on the top of the carb, but they seem to do nothing. Additionally, there is an adjustment on the Governor, but I do not have a service manual to know exactly what to adjust.:confused:
1. Any idea what the 2 adjustment screws are on top of the carb?
2. Any idea how to properly reduce the ideal speed?
Thanks in advance!
Glenn
uglyboy
TG1860G
Mar 8, 2013
87
St. George, Ontario
Hi... while 1200rpm might seem a high idle speed, especially for a car engine, it is not high for a 1 or 2 cylinder small engine.
My Kubota TG1860G gas 2cylinder Kawasaki engine idles at about 1200rpm.
This machine did not come with a tach, but I added one:
http://www.ebay.ca/itm/Tachometer-H...ash=item1a0fa3e4d5:g:rr8AAOSw0vBUan0y&vxp=mtr
I run it at about 3300rpm when mowing.
If you think your unit is idling too fast, I suspect it must be somewhat higher than 1200rpm.
Pete
summergs1
G2000-S
Apr 11, 2016
Marriottsville, MD
Thanks for the information!
I would still like to get answers to my original questions....
Tooljunkie
May 13, 2014
4,150
Generally adjustment screws are for idle mixture and speed. Not knowin engine manufacturer and type of carb its difficult to guess at what your issue may be.
If screws go into carb body, one is idle mixture other is like a main jet for over all ranges.
6,583
I usually check the rocker arm where the cable ties into the carb. On some, they have an adjustment screw for low and max throttle. I usually don't mess with any that go into the carb. That seems to me into trouble :D:D
summergs1
G2000-S
Apr 11, 2016
Marriottsville, MD
https://drive.google.com/file/d/0Bxk_T5u9G46KMHRrcy04UUxtSkk/view?usp=sharing
https://drive.google.com/file/d/0Bxk_T5u9G46KU2FwRTZrYktXY0U/view?usp=sharing
https://drive.google.com/open?id=0Bxk_T5u9G46KblZwS3J3SVQxSWM
https://drive.google.com/open?id=0Bxk_T5u9G46KcGlDd2VEQ3lzSmc
Screw1: I assume it is the slow idle adjustment, however, the Governor seems to be overriding this as it does not let the engine idle low enough to for the linkage to rest against the adjustment screen
Screw2: I have no idea what Screw2 is used for.
Screw3: I assume it is the fuel mixture adjustment, however, no matter if this screw is 0-turns from bottom or 3 turns from bottom, the engine is runs the same.
Governor Adjust: I do not know how to properly adjust this.
The engine runs very well, however, the idle speed is too high. The Kubota G2000 has a 3cyl gas engine.
lugbolt
ZG127S-54
Oct 15, 2015
5,207
1,893
Mid, South, USA
Screw 1 is the idle speed adjustment.
Screw 2 is an air bleed. Not adjustable.
Screw 3 is the idle mixture adjustment.
summergs1
G2000-S
Apr 11, 2016
Marriottsville, MD
Thanks Lugbolt!
Any idea why the Governor doesn't let the idle linkage rest on the Idle Adjustment screw? (Governor is causing the engine to rev around 2K RPM with no load.)
summergs1
G2000-S
Apr 11, 2016
Marriottsville, MD
I figured it out...the throttle cable was getting hung up on lever(dash) side.
Thanks for the info!
(not sure how to close this thread...but please consider this issue resolved.)
6,583
The thread stays open forever :eek::eek::eek: :D Glad you got it figured out. I find that's it's usually foolish and simple that sneaks up on you and kicks my butt :rolleyes::D
