My 1st Kubota. A G1900 with 1340 hrs.
Engine runs great from about 1/3 throttle to full throttle movement. Unit mows great and seems to have enough power for the 54" mower.
I crank the engine with the throttle (lever) at minimum. It will fire up within 3 - 5 seconds. But it idles really rough. Engine will run smooth after moving with the throttle at about 1/4 - 1/3 of movement range( even when cold). Will idle just as rough when bringing the throttle back to minimum after 3+ hours of mowing. I have been told by a diesel mechanic that all the Kubota diesels he has seen runs very smooth from idle to full throttle.
New fuel filters. Air filter "looks OK"; cleaned a couple of times with compressed air. Engine does not "smoke" (white, blue or black) when mowing.
We have three older diesels farm tractors (non-Kubota). They all run rough for a few minutes upon starting but will always idle smooth when warmed up and after several hours of use.
Any help will be greatly appreciated.
Charlie
Charlie
