Fuses
Johnbeaver
L3560 Limited Edition
Jun 18, 2026
Texas, Eastern portion
L3560 front fuse box. Just in front of radiator.
The battery was replaced. The connections were placed wrong. Neg to pos / pos to neg and the tractor was attempted to be started.
The 80 amp and 60 amp fuses, 1 &2 from left to right were blown.
‘When I puled the fuses the prongs on them remained in the fuse block. I have tried to pull them out with pliers with no luck. Pulled reasonable hard. Also, I could not pull the fuses by hand. Again I used -pliers to get them out.
‘Has anyone had this issue?
I’m afraid the prongs may be welded in. I do not see a way to disassemble the block, but I haven’t removed it yet..
10,875
The 80 amp is a male fuse the 60 amp is a female fuse.
So one set should have prongs in the fuse block, don't pull them out!
