Large boxes of fuses can be found on RockAuto.
Go to the very bottom of this page...
https://www.rockauto.com/en/tools/electrical,fuse,blade+fuse,120
Note the different styles...
ATM - has tapered legs, size of dime
ATC / ATO - square legs, size of nickel, “C” is closed at bottom, “O” is open
Max - size of quarter
(Use closed if possible)
http://www.cooperindustries.com/con...automotive_fuses/blade_fuses_atmatcmaxid.html
Bussmann ATCIDSK ATC-ID Fuse Assortment https://www.amazon.com/dp/B0038N0H9K/ref=cm_sw_r_cp_tai_WNIqCbA6FY66P
