I have an OLD B9200HST. Over the winter I THINK I had water in the fuel (not sure), so since then I have cleaned the tank and the fuel lines up to the pump. Cleaned an otherwise new fuel filter and replaced several hoses as well as the O rings for the filter fixture.
I have been trying to prime the system, but have had no luck.
I can pressurize the system by taking off the fuel return line on the left upper side of the tank and putting my air compressor nozzle to that, using low pressure. With that, I can make fuel flow up to the valve that is mounted on the injector block (I assume that that is what it is called, all the injector fuel pipes leave this block).
SO, I have fuel flow (pulses) when I turn the engine at that valve (remove the hose and open the valve). When I remove the injector pipes (loosen them at first) to see that there is fuel flowing up to that point, I get nothing. I took the first pipe totally off and I can see fuel pooled there at the fitting, but when I turn the engine (both with and without applying pressure to the fuel tank) I get no motion of that fuel. This is the fitting right on top of the injector block where the pipe to the injector attaches.
Do I have a problem with the injector block?
I have looked closely at the fuel cutoff and the throttle controls, but i have not disassembled any of that yet. Trying to keep the dirt and my inquiring mind OUT of where it should not be!
Looking for direction here!
Thanks!
Thanks!
