Fuel shutoff valve leaks
alsbigsky
Kubota L245DT
Sep 2, 2018
Berry Creek, Ca
I recently acquired a early 80's L245DT and the fuel tank shutoff valve leaks from the center of the shaft when turned on, not from where the valve is attached to the tank. The manual shows the breakdown of the valve with one O ring inside. Is it just a matter of removing the snap ring, the shaft, and replacing the O ring inside to fix the leak? And is it a special Kubota O ring, or just a standard metric O ring? Any advice is appreciated. Thank you.
BruceP
G5200H
Aug 7, 2016
851
368
Richmond, Vermont, USA
Most manufacturers source things like bearings and Orings from standard sources. As long as the material they are made of is resistant to diesel fuel, you should be OK.
Nearly EVERY hardware-store will have some Orings. Beware that Kubota is likely METRIC Orings.
If you have a local bearing-shop, they are often a good source for Orings and seals too.
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
643
256
Herald Calif.
Hello
You can just replace the o ring by removing the snap ring. I get the o ring from Kubota. I have not had any luck with generic Metric orings.
Good Luck Lance
alsbigsky
Kubota L245DT
Sep 2, 2018
Berry Creek, Ca
Thanks Bruce.
alsbigsky
Kubota L245DT
Sep 2, 2018
Berry Creek, Ca
Update...I was able to order a couple of new OEM 1980 L245DT fuel valve O rings and a cir-clip direct from the dealer. New complete shutoff valves are available, but other than that no other internal valve parts like the needle valve or washer can be ordered.
