I recently acquired a early 80's L245DT and the fuel tank shutoff valve leaks from the center of the shaft when turned on, not from where the valve is attached to the tank. The manual shows the breakdown of the valve with one O ring inside. Is it just a matter of removing the snap ring, the shaft, and replacing the O ring inside to fix the leak? And is it a special Kubota O ring, or just a standard metric O ring? Any advice is appreciated. Thank you.
