Fuel gauge showing empty
BruceMyers48
L3901, 6' Boxblade, 6' Mower
Nov 9, 2014
31
Zephyrhills, FL USA
Hi, the other day I started my L3901 up and the fuel gauge showed empty. I thought maybe someone had emptied my tank. Nope I filled the tank and it still says empty. Not sure if its the gauge or the sending unit in the tank. The fuses are all good. When i start the tractor, the gauge goes to the full make and drops right back to empty. Is there a way to check my sending unit and besides pulling the hood off to get to the tank are the units hard to replace? Thanks in advance
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,239
1,022
Williamstown Ontario Canada
First check simple stuff. Wire disconnected or chewed by mice.
From this WSM:
L3130 · L3430 · L3830 · L4630 · L5030, WSM
Likely very similar
Dave
5,687
Bruce, can you look in your fuel tank and see anything? Maybe you need one of those cheap borescopes! Sounds like something is causing the float to be caught on something so the resistor on the sending unit can't move.
SidecarFlip
Banned
555
Harbor Fright, 50 bucks. I use the heck out of mine and they even come in a fitted case.
vic gerbasi
M110 L3300
Feb 19, 2016
232
dugald mb canada
I have an L3300 about 20 yrs old. The fuel gauge has NEVER worked properly. the tractor is very economical on fuel so i have to check fuel level every once in a while thru fill cap
this unit operates extremely well all year, used mainly for hay moving and snow blowing/pushing. I would recommend this style tractor to anyone
Michigankubota
B2650 Loader,LX 2980-64 Blower ,60”MMM , Land Pride 60”Box Blade.
Oct 17, 2018
246
14
Bessemer, Western U.P.
My BX never shows full either, it reads full at start up then always goes down one bar and works correctly from there.
SidecarFlip
Banned
555
My buddy in Maine has a Deere with a busted fuel gauge. He uses a stick to check the fuel level. It never breaks, is always accurate and can be used for kindling if the need arises.:D
bambam31
L3800HST 4x4,R1,FEL, 6'disc, 5'bush hog,piranhaTB,6'grader,6'rake, 48"forks
Apr 3, 2014
319
26
23
Mobile, AL
I have the opposite problem. My fuel gauge always shows full. I forgot to tell the dealer when I took it in for service last time. I just deal with it.
