Fuel Gauge sending unit
fredwa
BX 1870
Lufkin,texas
On my BX 1870 The fuel gauge indicates full all the time.
Are there instructions available for locating and replacing
the Sending Unit?
2,720
On my BX 1870 The fuel gauge indicates full the time.
the Sending Unit?
All the time? mmmmmm......
now mine (2370) will read full a good long time, but if I get a low and move on a hillside I can get it to move off the full mark....
those sending units have a bad way of "breaking down" inside the tank and causing clogging problems....
If you get on an incline .....no change at all?
YOU might have an electrical problem too - many sending units will read FULL when grounded out thus bypassing the variable resistor (POT) that changes the reading.
Jpatrick
BX1850, L210, Various 3 point implements
Apr 4, 2017
100
Buckingham, Pa
The problem might not be the sending unit.
I've read elsewhere that the float corrodes and ceases to work in some of these Bx tractors. Mine sort of works, but the reading on the panel isn't reliable. I manage this by just filling the tank after I use it.
Assuming corroded float assembly is your problem it can be fixed, but I personally don't think the teardown is worth it.
6,269
You say the problem might not be the sending unit, then the problem you describe IS the sending unit. The float assy slides on a resistor that tells they gauge fluid level.
anthonyv
BX24 BX2200
Jan 24, 2017
122
19
SC
Several threads about sending units rusting out & causing all sorts of problems.
Only way to get to it is removing ROPS, knobs, then lift fender to reach sending unit. Been thru two units on two different BX's so far, keep a spare on the shelf.
Jpatrick
Apr 4, 2017
100
Buckingham, Pa
I guess we have a difference of opinion on nomenclature. In engineer-speak, I'd consider the float the level element. The variable resistor would be the level transmitter (i.e. sending unit). What you see on the panel would be the level indication. On instrument diagrams, these are identified LE, LT, and LI, respectively.
Now, it is common to to have instrument with element and transmitter together, and that's perhaps the source of confusion.
