Fuel filter
DONLI
L3301,FL, MUSTANG 2054 SKID STEER, 6FT HYD. SNOW BLOWER,and other things of labo
Jul 28, 2025
104
88
duluth mn
I just changed the fuel filters on my L3301, what a bpia it is to get to the shutoff valve and get tha filter bowl off. ( Sure not as easy as my L3010 GST that I wish I still had!)
Anyway does anyone know of a bracket to relocate it to a place that is easier to get to?
Thank you!
Don
Bee-Positive
BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
681
707
Amsterdam, NY
Made my own bracket from flat stock to go where it fit best, a few barb connectors, some hose, couple of shutoff valves to isolate the filter, good to go. Now I just raise the bonnet and both filters are in easy reach.
4,952
I can’t answer your question directly, but keep in mind this;
If you can get to it easliy…..So can a stick….
I only had about 3 hours on my machine when it suddenly died……I was like “WTF????"
Then I looked down and saw my fuel filter and cracked bowl, laying on the deck.
I ended up making a “cage” for it, so it’s "all good" now, but just something to keep in mind.. (y) (y) (y)
4,060
As often as you change that filter……(few and far between)…..… forggettaboutit…..
Just put up with the location Kubota designed for a reason.
4,060
A manufacturer's engineering and cost reasons did not include our convenience.
…or their own.
My comment was intended to bring to mind the cost-to-benefit ratio of an item so rarely serviced.
Trash Panda
L2501
Feb 18, 2022
174
157
Wyoming
…or their own.
Likely spend more time moving the thing, than you will ever spend servicing it over the life of the tractor.
To some people, the juice is worth the squeeze though.
whitetiger
Nov 20, 2011
3,494
1,926
Kansas City, KS
He is actually referring to the water separator, which is located right below the RR corner of the fuel tank, above the brake pedals.
I have never heard anyone complain about its location before. I always thought it was very easily accessible.
