I have a L3000DT 4whl Drive. Does anyone know where the fuel shutoff valve is located? I want to change the fuel filter and I'm tired of getting full of fuel because I cant locate the valve.
Roger
Roger
I can't say for certain on your model but most do not have a shut off anymore. So do the needle nose vise grip trick upstream from the filter. Just squeeze the hose to pinch off the fuel till you change the filter.I have a L3000DT 4whl Drive. Does anyone know where the fuel shutoff valve is located? I want to change the fuel filter and I'm tired of getting full of fuel because I cant locate the valve.
Roger
I am one of those people. Yes it can and has been done for years by many people. I would never encourage it's use to be considered routine but rather an exception. Instead, prep the machine for such and install a shut off valve like many others have.I agree with Theekillerbee. The vise grips will work great but you no how some people are. They think if you touch a fuel line with the vise grip teeth it will need to be replaced. We have used that little trick for years ourself.
