Frozen/stuck Bolt in Aluminum. Plasma cutter?
Tooljunkie
May 13, 2014
4,150
An old departed friend had a caterpillr d6 break off the drawbar. 1-1/4" bolts broken off flush. Drilled a 3/4"hole down through bolt and a reciprocating saw to split bolt and collapse. The cat bolts are hard,but not as hard as the plate they were threaded into.
It takes a little nerve to burn a steel bolt out of aluminum, and a steady hand.
Glad you solved your problem.
forceten
BX 25d, Grand L6060, Kx040, GL7500, ZD1211 With cab
Sep 4, 2015
281
26
New Jersey
That's why I came here first to ask. To see if somebody would talk me out of it or point out something I wasn't seeing. :D I was a tad nervous, but other than a good bit of spatter (and I was covered up very well) it was easy peasy. Just steady hand and centered and sploosh
3,682
Ya got more knuts than I would have had,,, happy you got it
