Front wheels don’t spin when elevated
10,885
No, both off the ground.
???? o_O :unsure:
I'm really confused, you said NO, then said the same thing i said?
So which is it?
NO, both were not off the ground at the same time.
Or
Yes, both were off the ground at the same time.
whitetiger
Nov 20, 2011
3,636
2,060
Kansas City, KS
If you have the front wheels off the ground and the switch in the OFF position, the engine has to be running, or the clutch pack will be engaged. The front axle can not be disengaged while the engine is OFF.
You must have the Deluxe model, which has a spring-engaged, pressure-released front axle drive clutch pack.
The Standard model has a lever to the left of the operator's seat, which is a sliding coupler to engage the front axle.
10,885
And the Tigger with the answers chimes in! 😋 ;)
Thank goodness! :)
