edritchey
2026 Kubota ZD1211L-3-72 - 2025 New Holland CNH WM75
If you are running a snowplow blade on your loader arms does the blade float (pivot up/down) without floating the loader arms?
I had a 8’ hydraulic angle plow built that will float. I also use cylinder ram limiters to keep the loader from lowering to the point where it will touch the ground.
With this combination I can lower the loader in the float position and not touch the ground then I can tilt the blade to touch the driveway surface and it will pivot up (float) as it rides the surface. My blade has a thick hard rubber edge which acts like a squeegee and cleans the blacktop off without marking it up.
My old Land Pride snow plow also had the poly edge but sucked because it didn’t have any up and down floating ability I had to float the loader arms and put up with all that weight pushing the blade against my driveway surface.
I’ll post some pictures of this snowplow when I get a chance. I was just wondering if anyone else is using a setup like I just described? I still hope it never snows again
