Front hydraulic block
stabota
Kubota Sunshine Tractor L1-R28
Aug 18, 2019
10
castlegar, bc, canada
Hi everyone, I'm looking for a front hydraulic block that I can install on a L1-R28 kabota. This tractor did not come out with one and it has had a fel installed. The pump has no relief valve protection when the hydraulic lines to he loader are parted. ie: quick coupler popped apart with engine running resulting in a destroyed hydraulic pump. Front hydraulic block with relief valve would have prevented that. Any help or suggestions will be appreciated.
3,513
There are any number of relief valves that could be installed in the pump supply line. Here is an example:
5,357
That block is the same or similar for the L2250, L2550,L2650,L2850, L2050, l2450, L2950, L3450, L3650.
The fittings will be BSPT or BSPP not NPT.
Here is one for sale:
