Front End Loader Curl not holding position
TomD406
L2500
Feb 11, 2024
Helena, Montana
I have a older 2500L with a bush hog Front End Loader. The curl cylinders are not able to hold position over time. It takes only a few minutes for the cylinders to fully extend out if the bucket is not down on the ground. Hydraulics are kind of a mystery to me. I'm usually ok with mechanics in general but with hydraulics i'm lost. The overall fluid level is good and both the main lifting cylinders and the 3 point arms seem to hold their positions.
Thanks in advance!
Vlach7
L47 305DT JD500C
Dec 16, 2021
265
169
Frazier Park Ca
Could need to rebuild your hydraulic rams, that's what fixed mine, at only 400hrs on it. Otherwise could be the Spool/Control valve. Start with the rams.
jyoutz
Jan 14, 2019
2,517
1,624
Edgewood, New Mexico
Yep, most likely the cylinders need rebuilt with new seals.
3,386
Thanks in advance!
Most likely the piston seals in one or both cylinders are leaking. To test the cylinders disconnect the base end hose at the control valve and cap it. Start the tractor and move the loader control lever to curl and hold it there. The cylinders should not move. If the cylinder(s) extend the seals are leaking.
TomD406
L2500
Feb 11, 2024
Helena, Montana
Thank you for the advice all. I've had to focus on other issues for the past few days. Will get a chance to try out the test on these. May have more questions when I get over my head!
