Front chains on a BX?
Blue2Orange
BX2380 with LA344S & QH05. SB1051. SG0554. BB1248. RB0560, Vassar dirt bucket
Apr 3, 2025
242
133
Bayview Township
Assuming the Euro diamond or H pattern chains have improved side grip and steering? If so, wonder regarding steering on front wheel mounted chains if the spiked/studded 2 link ladders are more or less effective than those.
Even with the ballast of the FEL and bucket, the R4s front tire traction is less than expected or what I was use to in the larger NH. NH had R1s about size of the BX rears. Not sure if tires and size are the reason. Guessing it is just the significantly heavier loader and heavy duty bucket I had.
H pattern for the BX found on line are a bit on the expensive side. No luck still finding a Euro diamond sized for the 18 x8.5-10 fronts. The studs on the 2 link ladder chains look to have similar side clearance as the std 2 link ladders. Thinking the only clearance issue to be concerned with on the fronts are inward towards the steering arm knuckle or whatever is the correct description. Considering front chains to improve steering control and assisting straight line traction.
BX23-S,57 A-C D-14,
5,869
ANY kind of chains up front will help ! Wished I'd had them today moving a cement mixer. It was 'ok' going to the drop off location, NOT 'fun' coming back up a 10% grade with zero weight in the bucket. R4s ain't 'snow tires' !
MattB3200
2010 B3200 with LA504 loader
Dec 1, 2025
Otter Tail County MN
I have a B3200 and a steep driveway in Minnesota. A buddy gave me a set of chains that fit on the wheels, but they rubbed on the steering arms on the inside of the tires.
Bee-Positive
BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
504
502
Amsterdam, NY
Pushing heavy snow or plowing on slick surfaces chains are a must for my BX. I've plowed and used the bucket a couple of time so far this year without chains but the snow has been fairly fluffy. The time will come when they have to go on.
I use the ladder 2-link heavy duty without v-bars for my turf tires, $145 at tirechains.com.
