If someone could offer up some advice I'd appreciate it.
Last week I purchased a 2011 Kubota BX25 & since then I've put ~8 hrs. on it. Today, I unloaded the BH & FEL so I could go thru everything & make sure all is right. Pretty much everything is good, except the front axle oil. Specs. call for 5qts. but I couldn't even see any oil on the dipstick & all I could get out of the 2 drain plugs was ~2qts. total.
Tomorrow I'll, at the very least, go get the oil that I was shorted when I purchased the tractor, but should I be more concerned, than pissed off? I know it's not leaking. The oil that I did drain was clear, no metal that I could find. Lastly, I would say I've had the front drive engaged about half the time.
Thanks in advance, for anything you guys think of..?
Wormwood
Wormwood
