Front axle leaking oil
marvmerritt
louisville, tn. usa
L3830d The left front wheel locked up later in the day it unlocked while driving to house I noticed it leaking. I drained the oil it was milky I noticed the bottom seal Partly started off that is where it was leaking. Should I replace the upper seal also or just change oil and keep eye on it?
GBJeffOH
L4060, EA Grapple, 6' LP Brush Hog, 8' snow plow, 6' LP tiller, EA Forks, Spraye
Nov 17, 2014
321
147
Jefferson, Ohio
I would replace both seals. I think there is a good chance you had a bearing go out.
You need to know why the wheel locked up.
I broke the bearing on my L3540. It was not to bad of a job.
The upper seals leak often.
rentthis
1,010
25
summerville,sc
I don't know what you mean by "locked up". If it quit turning, you have a problem other than just oil. It would be a good idea to look inside the hub and see what is going on. It would be helpful if you would give a better description of the symptoms.
marvmerritt
louisville, tn. usa
Ok thanks. I thought the water could have been frozen in the hub because later in the day I moved the tractor and wheel rolled fine. But I’m thinking I’ll replace both and inspect for bearing or gear damage
