Freeze Plug
sotubre
T1600H Lawn Tractor
Apr 7, 2012
BRYANT, AR.
Mt old T1600H is leaking water through a freeze plug hole. Is there any way too repair?I removed the starter and could see the leak crack.
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
That's usually an easy fix. Pop out the plug, catch all the coolant with a bucket below it, pop in a new plug. They're pretty cheap.
5,733
Do you just push the old plug through?
No - pull the plug out.
Do a search for "freeze plug" here, and I think you'll see some suggestions.
Seen several different ways to take 'em out.
Kanook
Kubota B2650HSDC Kubota RTV900
Jun 29, 2015
32
Almonte, Ontario
When I installed a blockheater in my Kubota RTV I had to remove a frost plug in the location where the heater goes. Using a slotted screw driver and a small hammer I tapped repeatedly on one portion of the edge of the frost plug which caused it to rotate out on the opposite side and allowed that protruding edge to be grasped with a pair of pliers...just needed to be careful not to punch the plug into the block.
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
11
Gambrills, MD USA
If there is a spot, on the FP, that looks sound, take a drill/driver, and screw in a SDST sheed metal screw, and then take a crow bar or cat's paw, or dent puller, and pry or hammer it out...:D:D
sotubre
T1600H Lawn Tractor
Apr 7, 2012
BRYANT, AR.
Thanks for the information I'll give it a try,the Kubota is at the lake and will be a while before I get up there.
