Mt old T1600H is leaking water through a freeze plug hole. Is there any way too repair?I removed the starter and could see the leak crack.
Do you just push the old plug through?That's usually an easy fix. Pop out the plug, catch all the coolant with a bucket below it, pop in a new plug. They're pretty cheap.
No - pull the plug out.Do you just push the old plug through?
22 degrees here this morning.Kubota is at the lake and will be a while before I get up there.
