Four way loader buckets ?
Lowlysubaruguy
b7800 l4701
Oct 3, 2025
52
12
Big Island
Ive found a 2023 L3560 grand thats new sold by a Kubota dealer. It has a four way loader bucket. Im on the fence mainly because of the bucket. But maybe you can help clear up some of my concerns or questions. I could package another stock bucket in with the purchase. This tractor will do a lot of loader work digging gravel and rocks moving and leveling a long driveway and a lot of just land smoothing that will require loader and box scraper work.
The price is decent its not an amazing deal but its enough tractor at a price I can accept.
Shawn T. W
Dec 9, 2024
651
1,214
SW Missouri Ozarks
The 4 in 1 bucket is going to be probably at least 50% heavier, which means there is that much less weight of material you can lift with it ... However it also means it comes plumbed with the hydraulics up front which isn't a cheap option ...
I'd probably opt for a standard bucket to go along with it.
BAP
Dec 31, 2012
3,113
1,248
4 in 1 bucket is heavier and tends to be more rugged than a standard bucket. They are great for grabbing and moving objects as they appear when you are digging and leveling material, things like bigger rocks, sticks, logs etc. They also are great when loading over something high sided because you can just open the bucket up to dump. We always had 1 of our 3 payloaders set up with a 4 in 1 bucket over the 40 years we had them.
Caden
1979 B7100
Apr 16, 2026
23
9
I would personally prefer having the standard bucket. 4 way will never have the lifting ability of a grapple, nor will it be as good as a regular bucket for moving gravel, because of the weight.
As for the blade and box scrapper functions of it - I believe tractors are better suited to work off the rear of. You will have far better control and visibility dragging a box behind you than in front of you off the loader.
I can see the potential on maybe a skid steer or wheel loader for a 4 way, but I'm not convinced for a tractor. Maybe I just don't have enough experience with one to fully appreciate it.
SDT
Apr 15, 2018
3,599
1,335
I once owned an L6060 (recently sold) with FEL and Kubota 4-way bucket. The bucket was sometimes handy but always heavy, reducing payload significantly. The only thing that I used it for was occassionally picking up drift wood or cut logs from downed trees. I would not buy another one.
SDT
Apr 15, 2018
3,599
1,335
Agreed.
I once watched an experienced skid steer operator using a 4-way bucket to move and level crushed stone in preparation for pouring a concrete floor for one of my post buildings. Guy was an artist and the 4-way bucket was the cat's meow for his work but I found the one on my L6060 to be of limited usefulness.
Lowlysubaruguy
b7800 l4701
Oct 3, 2025
52
12
Big Island
thanks for the input. I also watched a couple videos of one in use. It’s probably a semi useful tool. Im going to add a standard bucket to the list if I do buy it. I’m still waiting for the dealer to get me a price in writing. Funny he should have wrestled me into a chair on the spot I was ready to buy it. but I guess that’s how you end up with a three year old brand new tractor on the lot.
SDT
Apr 15, 2018
3,599
1,335
In many markets, it is not uncommon to find aged new equipment on dealer lots.
Be advised that manufacturers usually add aged inventory incentives to such tractors.
No, your dealer will likely not tell you of any such incentives and will simply pocket the cash if possible.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,149
2,772
Near Lancaster, PA, USA
A 4-way bucket looks like it would be fun. From the replies above it sounds like it would bring limitations. Maybe the best of both worlds would be if the seller included a regular bucket so the 4-way could be used if you wanted to play.
