jmf78
BX23S W/ Factory Deluxe Cab, 60" MMM, 60" BX-2612 Snow Blade & BX-2816 Blower
Gee wiz Wolfman! Thanks a lot! [emoji23] Just kidding.Well I kept quiet and wish I won't have.
I wanted to suggest you just bend the line so that the Quick connect fitting plane would clear the back of the cab.
In other words bend the line so that the fitting pointed towards the rear a little.
You should have no issue with bending the line back and then a little farther so it will clear the cab, the lines are made from soft steel giving them the ability to not just crack from sudden changes in hydraulic pressure.
Seriously though, thanks for confirming that I can just bend the line back to where it needs to be and go back to the straight in connection. Appreciate it. [emoji106]
