flail mower or rotory brush cutter
11,757
New-ish tractor owner here (approaching 1 year). After much research, I got a Del Morino Centurian 158 (not the 'super') with hydraulic offset and hammer blades. It is quick hitch compatible. The hydraulic offset isn't much of an offset, about 11 inches, but works very very well for grass, brush, small saplings, etc. I love it!
The only reason (besides cost) I didn't get a "super" series like the one posted above, is I have an LX4020, and it would have been too much offset weight for my tractor.
Welcome to the forum! Nice tractor and flail mower. (y)
This year I'm going to test the Del Morino Centurion Super 158 with the QH10 to see if it interferes with the PTO shaft. The literature says that it's not QH compatible, but I see that Speeco QH owners modify they're QHs to run standard rotary cutters but I've never had to do that with a QH10 or QH15 so perhaps it'll work.
Hal9000
2023 Kioti CK 4020 SEH
Apr 22, 2026
NM
Now I’m curious about max height for a flail. I have to cut our meadow areas where we want native forbs at 8” once a year in the winter, which keeps saplings at bay but allows native pollinators to out compete grasses. 8” is as high as my bush hog cuts, but is also minimum for our forbs. The areas we want grass I cut at 4” a couple times a year because that’s low enough to kill both saplings and our native forbs while remaining friendly to most of our native grasses.
Do flails not have the ability to cut at a height of 8” or more?
I do understand any mower would cut higher by raising the 3 point and not having the guide wheel/roller on the ground but that would not work well anywhere that isn’t flat.
I was looking to purchase a flail mower for my property in the mountains in SW New Mexico. I am rethinking it now since I am like you and need to mow no shorter than 5 inches. I don't want to scalp the native grasses. Every company I have communicated with state their maximum height is 2.5-3 inches. I have heard if you just raise the mower up a bit the cut is not as good and it puts stress on the 3 point attachment of the tractor. Seems like a company could put a larger diameter rear roller or an adjustment to be able to cut higher. With my propery a rotary moter would's be as efficient with some of the pine trees I have and have to mow around.
6,844
One of the fields I have to bush hog has small trees planted in a 30’x30’ grid with a few random trees mixed in. Thankfully it’s small. It’s one of the reasons HST, independent PTO, and removable loader were a hard requirement when I bought my L. To me, the rotary cutter is a mixed bag with trees. The tail swing is a major downside. The ability to back the mower under low tree limbs without getting the tractor very close is an upside for smaller trees or trees with low limbs.
11,757
If you have an hydraulic top link you can extend it to increase the cut height while keeping the roller on the ground.
Hal9000
Apr 22, 2026
NM
I do have a hydraulic top link. Thank you for your response.
LBZ
'25 GL6060
Sep 17, 2025
50
82
Iowa
So, I decided to go with a flail. With the roller set to allow the highest cut and using the hydraulic top link I can get the hammer blades from 7 inches above the shop floor to 2.5 to 3 inches above the shop floor while keeping the roller on the floor. I believe I'll be able to keep it at almost any height while mowing over clover as long as I'm not trying to go over saplings or anything that would make the machine bounce on the 3 point.
It arrived with the machine broken through the shipping pallets but undamaged. Making it difficult to unload from the semi. The carriage for the hydraulic side shift was not attached. Pretty self explanatory but no instructions provided. Took a little time for me to figure out exactly where to mount the
hydraulic cylinder. Also the grease zerk for one of the roller bearings is just stupid. Why not put a 45* zerk or rotate the location where it's reachable?
Just got it assembled yesterday and it's too wet to try mowing so have not used it yet.
1000003701.jpg 1000003702.jpg 1000003703.jpg I
6,844
I know you haven’t used it yet, but when you do…
If you roll it back with the toplink to get the full 7” height, does it run smoothly or do the PTO angles get dissimilar to the point it chatters?
LBZ
'25 GL6060
Sep 17, 2025
50
82
Iowa
So without actually mowing I ran it at 540 rpm pto speed with top link fully extended and shifted completely to the right, roller on the floor with no chatter. Hopefully I'll have a better report as soon as it dries up a little. Really can't complain as we have been in a moderate drought.
11,757
I've run my Del Morino Centurion Super for four summers and have cut a lot of different types of vegetation with it. The PTO shaft angles are way more severe than they are with the Flipper shown above and I don't get any chattering even with the flail offset all the way over to the right. Greasing with these things is not something to be casual about.
11,757
I had similar issues with a broken pallet when I received my Del Morino in March of 2023. However, there was also some damage to the rod that the front guards hang off and some damage to the belt guard. I got everything resolved to my satisfaction, and Courtney is a stand up guy and I'd buy from him again. I reached out to Del Morino in Italy to ask how they ship their flails to the US since I wondered if GWTC was removing them from a crate and stuffing them on cheap pallets but I didn't get a response from Del Morino on that. Shipping companies can be brutal so the ideal approach is to make the crate or pallet virtually idiot proof.
Both of the drum bearings on my flail have the zerk fitting orientated at 12 o'clock so not an issue, but I have an OTC grease gun adapter kit to account various zerk orientations. It's worth noting that the roller bearings on my flail are mounted using four bolts so obviously a different part.
6,844
Thanks! It looks like a very nice mower. Just a little jealous, particularly the side shift capability.
LBZ
'25 GL6060
Sep 17, 2025
50
82
Iowa
Update on Del Morino flipper. Works great clearing brush and mowing tractor trails. Eats multiflorarose and saplings right up. With roller on the ground and top link fully extended I didn't like how much was exposed to possibly throw stuff at the cab. so mowed at about 4 to 5 inches It tosses a good amount of small debris on the rear of the transmission and PTO outlet anyway.
What little I tested it on grass it looks like I can cut any height I want by holding it up via the 3 point. Wanted try to cut some cereal rye like a foot high but before I was done with the last tractor trail I snagged the end or some woven wire hidden in the weeds and wrapped some up around the hammer drum right at the bearing, so when I get that problem fixed I'll go back after the cereal rye and some clover.
mikester
M59 TLB
Oct 21, 2017
4,143
2,833
www.divergentstuff.ca
Any updates? I’m looking into the Del Morino 72" Boom mounted Flipper Super 186
LBZ
'25 GL6060
Sep 17, 2025
50
82
Iowa
Still working good. probably have about 20 hours of mowing time on it. Had one spot where iron weed and milk weed had over grown some brassica, weeds were about 5', Tried to mow them off at about a foot or so but it left the about 1" thick stems behind. Had to git the roller on the ground to get the stems cut. probably cut everything to about 8". This is the only flail I've had but I am satisfied.
OrangeColoredTractor
2017 L2501 4WD HST
May 10, 2017
75
23
Washington
I have a flail for my property with hammer blades and I am a big fan of it. Mostly for weeds and trail maintenance . I don't really have grass, just trees and trails to maintain. I only use it maybe three times per year.
Good luck
J
I just bought a brand new flail mower, hammer type, 60 inch, its a MechMaxx brand, EFS60, got it through amazon, better price and free ship. I have 40 acres and when I was in my early 20's worked at a golf course and we had a John Deere 1050 and we used a flail mower for heavy brush, it would grind it to nothing. I plan on using this to Keep my fire danger to a minimum after having all 40 acres thinned with a ASV120 skid steer with a Fencon forest mulcher. One guy with 40 acres, monumental task, this should help.
This is the unit I got, bought spare hammers and belts.
