First tractor, not the first problem
kfd378
10
Hahnville, La
Kubota L2050 I bought it with a 5' rotary cutter a month ago. Some days i raise the cutter and it is level, other days the right side is hanging 4" lower than the right. I can drive it around, work the hydros and the same thing occurs. All the tractor bars are eyeball level. I added hydro fluid and same results....all help is greatly appreciated! Thanks!!!
whitetiger
Nov 20, 2011
2,942
1,399
Kansas City, KS
Your latch for the disconnect to extend the Right side lift arm is probably not latched. Take the Rotary Cutter off of the tractor and see if the end can be moved in and out. When moved in, it should latch into place. They may just need cleaned and lubed or the latch repaired.
