bbxlr8
Background:
I am a new owner @ about 3 months& 35 hrs and getting comfortable doing all sorts of work on my L2501 TLB. Mostly backhoeing, some loader work, and recently gotten around to cleaning & clearing up all sorts of stuff that piled up around my place. I had the grapple on for the last couple of weeks and have done about 20-25 loads of rotten logs w/ my little old overachieving 4'x8' utility trailer (each load in the 1500-2000 lbs range). I was dumping into a ravine up the mountain, so unloading was a calculated push after very carefully backing onto a sloped ramp I made with the backhoe. Gravity can be your friend AND enemy!
Confession:
So... yesterday I was getting a bit cocky and was into an area between a steep hill and scrub forest getting at a large deadfall & massive stump (3' diameter trunk in 8 ft sections, totally wet & solid, but rotten). Was going after the last piece and ended up slipping back into the scrub area. I had mostly cleared and walked it beforehand and was maneuvering around some low stumps, so I thought I was in the clear. Famous last words...
Full story:
I ended up hung up on an unseen round boulder similar to a mid-size beach ball. It was at the edge in deep weeds and I didn't know it was there or that I was on it. I thought I was slipping in the mud and tried a bit of maneuvering. So dumb me throttled up and hit the diff lock and tried to power out left & right still not realizing I was rolling around ON the rock. It was actually loose and very round both of which were working against me. Once I realized, I should have stopped and thought it through, but instead, I picked a path and eventually powered my way off it. I have a good amount of off-road experience (long-time jeep owner) and knew there was no way to pull out with a strap or any sort of recovery etc. It was very hot, late & I was tired and trapped in by the steep slope and woods, so I had more than a bit of panic in getting it out of there.
Lessons learned:
I fully expected severe damage knowing all the filters/ linkages that are exposed under there. I was relieved that the BH subframe took all of the abuse (i.e acting as a rock rail). I am now thinking about some sort of belly pan or guard. In reality - I need to learn to STOP and assess and should have known better! Hindsight being what it is, it hit me late last night that I had all of the tools I needed on board with the backhoe/stabilizers to pick up and roll it out from under there safely. I was so tired and tunnel-visioned into quickly solving the problem at hand.
Call me stupid (& lucky)!
Confession:
Full story:
Lessons learned:
