First Kubota
dzldanz
L4060
Mar 7, 2025
Ottawa,Ontario
Im in eastern Ontario OTTAWA , CANADA. where we get plenty of snow. Maintaining one paved lot and one gravel lot .I'm upgrading from a 2006 John Deere 3320 cab model with front blower and quick connect front blade. I'm about to order my first Kubota with the same attachments for snow removal only. Thinking of adding the air seat and front fenders. L4060 HST cab model. Thoughts? Any problems with the seat?
hodge
Nov 19, 2010
2,935
497
Love, VA
Welcome to the forum!
SDT
multiple and various
Apr 15, 2018
3,264
1,061
SE, IN
I'm upgrading from a 2006 John Deere 3320 cab model. I'm about to order my first Kubota for snow removal only. Thinking of adding the air seat and front fenders. L4060 HST cab model. Thoughts?
Don't know where you live, how much snow you get, whether you plan to plow, blow or both, all of which would help.
The GL series is a great series, if becoming a bit dated.
Since you state that you plan to use if for snow removal only, you might you want to consider other snow removal options?
Might want to consider a RTV X1120C with plow or blower?
Of course, the most effective equipment to use depends upon the areas that you need to clear.
FWIW, the GL6060 that I recently sold prior to downsizing in preparation for a 1.700-mile relocation, was the most productive and versatile tractor that I had ever owned for my purposes encompassing a 50+ year tractor using experience.
Sidekick
Jul 29, 2023
861
1,023
N.Y,
I definitely wouldn't recommend a rtv over a tractor for plowing after using both. Shifting of a rtv is a real pain in the axx I have found compared to just using a foot to reverse on a hydro tractor.
8,051
Not sure about the front fenders, but the air ride seat is worth it to me. My first MX6000HST didn't have an air ride seat, but when I ordered the MX6000HSTC I chose that option with zero regrets. I like it enough that I even bought the air ride pedestal for the Grammer seat in the M6060. Both of my tractors have Grammer seats which I think is a really good seat. They're different but both are very comfortable over 8 hour days of mowing and such.
What I'm saying is that if you order the air ride seat in the L4060, it'll be the cloth covered Grammer seat and not the vinyl. By the way, if you order, you get to keep the original seat and any other parts that come standard but can be upgraded. You might have to mention that to the salesman since some dealers will pull parts off and put them on a shelf to sell.
SDT
Apr 15, 2018
3,264
1,061
SE, IN
Used just about all options.
As stated, depends upon areas needing routine clearing.
It is readily apparent that the overwhelming majority of those who clear snow commercially, use trucks with plows rather than tractors.
Again, depends upon areas needing clearing.
8,051
There's more nuance to this than you provide. Commercial snow removal typically involves the need to get from A to B at a reasonable rate of speed, and certainly faster than most tractors are capable of. Even 50 kph (31 mph) is considered fast for a tractor on the road but way too slow for most commercial operations.
But take away that part of the equation and I'll happily put my MX up against any pickup truck when it comes to snow removal. With a front blade and rear blower you're not going to find that level of flexibility with a pick up truck. It's not practical to put a tractor on a trailer and haul it between snow removal jobs, so their use is limited for a commercial application. Not to mention that many offering that service up here use their trucks for general transport and hauling all year round and will run a front plow (and maybe a salter/gritter) on the back during the winter months.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,354
1,547
Near Lancaster, PA, USA
Apparently these guys think tractors do OK:
chim
Jan 19, 2013
2,354
1,547
dzidanz, please keep in mind that this was my parking lot experience with one tractor (L3200) and one blower (64" Prononvost Puma). Different equipment may produce different results.
Driveways and small areas like driveway turnarounds were a lot of fun with the blower. Just ease into the snow and send huge white roostertails. I was not impressed with the blower for cleaning parking lots. The main problem was re-blowing the snow. The lots were too wide even starting in the center. The blower only threw the snow so far. Next few passes were OK. Then I started getting into snow that had already been blown and it was denser. The wider the lot the worse (heavier and denser) it got.
Then I switched over to an 8' power angle truck blade and it's been great. Much faster, no shear pins to break. It's mounted on the loader so I can pile the snow as needed. It's one of the "underslung" installations so it's closer to the tractor and doesn't act like a rudder.
BBFarmer
Jul 12, 2024
240
432
Terry, MS
No complaints from my base model seat.
I often enjoy getting launched from my seat on occasion.
Happens more if I get above a face melting 3.5mph while cutting.
Had i thought about it, probably would've upgraded to air. I'm sure its life changing. Probably will one day.
SDT
Apr 15, 2018
3,264
1,061
SE, IN
Bingo.
Hence the overwhelming popularity of trucks with plows for commercial snow removal.
Again, for the third time, it depends upon areas needing snow removal.
I routinely see municipalities using skid steers, rubber tired front-end loaders, quads, even road graders, but mostly trucks with plows removing snow. I do not see municipalities using farm tractors to remove snow.
No, I have not said that it cannot be and has not been done.
8,051
Life changing might be a stretch. 😂
I will say that the cloth covered Grammer seat in my M6060 is super comfortable without air ride, and more comfortable than the cloth covered Grammer seat in the MX with air ride. Also, the Grammer seat with air ride in the current MX is more comfotable than the standard vinyl non air ride seat that came in my first MX. Confused yet? So seat design is an important part of comfort, regardless of whether it's air ride or not.
I'm still going to install the air ride pedestal in the M this spring since I have it, and it will be interesting to see how much more comfortable it is compared to non air ride. The other thing to think about is ease of adjustment with air ride. It's a lot easier to adjust the firmness of the seat with air ride than it is with the standard lever/knob that you need to turn for the standard seat. I've owned and used two Kubota tractors with standard seats and spent a lot of time in two tractors with cloth Grammer seats with and without air ride, and I know which I prefer.
Sidekick
Jul 29, 2023
861
1,023
N.Y,
I have a cloth covered Grammer suspension seat in my tractor and it's very comfortable. They breathe and don't get hot like black plastic. Definitely a nice option.
8,051
That's part of my point re the air ride option. I don't think you can get a cloth Grammer seat in an L6060 or below without choosing the air ride option, but I might very well be wrong about that. The Ms come with cloth Grammer seats as standard, but every non M tractor I've seen has a vinyl seat as standard.
