Firewood Processor build
tpmx
2013 B3200
Jan 12, 2014
37
United States
Sorry,havent back on here lately,took a break tonight from working on anything
so found some time to check out the site and see whats new
I have ran about 20 logs through the processor after pulling the spitter assembly out of it to completely weld it up.
Everything works good except the log clamp.
Even though it does hold the log I am just not happy with it so I have taken it off and am in the process of building a new clamp/guide system
I turned some parts this evening for it and over the weekend I designed the clamp arms in Mastercam and set the cnc mill up and cut those out.
Tonight I made up the cylinder mounts also in Mastercam and now I need to get some material to machine them out of.
Sent off another order to Surplus Center for a couple more hoses and fittings
Hope this is the end of parts
There will be 2 cylinders plumbed together with each operating its own clamp arm.
When open they will act as a guide and when in place they will clamp down on the log.
I also have a pressure relief valve in line to limit the pressure that it takes to clamp the log solid
I will take a few pics shortly of the process of making the parts and hopefully this weekend of the processor running
As far as the saw it works very good and the splitter has had no problems splitting what I have cut
The saw mill brought me two loads of logs so I was running some of that material
ShaunBlake
Dec 21, 2014
899
Tooljunkie
May 13, 2014
4,150
Didnt want any sawtooth edges to hold log?
Would think a few points on those canadian inspired clamp bars would take less pressure to hold. (Reminds me of hockey sticks)
Mind you, with points the short blocks could stick and cause some grief.
Looks like they will go down to some pretty small logs.
tpmx
2013 B3200
Jan 12, 2014
37
United States
Yep,its going to get some teeth as soon as I get the time.
The arms will hold a smaller dia log then I will probably run through it
Happy with this system
Next is a heat sheild around the exhaust to keep the heat away from hoses.Getting close to taking it all back apart to sandblast and paint
Wiam
Barnet,VT
Curious as to how the electric clutch has held up over time. Does a single belt have any slippage problem?
Thanks
sheepfarmer
Nov 14, 2014
4,451
679
MidMichigan
Tpmx has not logged on to the forum for several years, so you might not get a response.
SidecarFlip
Banned
555
One of my other pursuits is I sharpen chipper knives for tree contractors and one of them just bought a commercial processor. Pretty neat machine. Pretty expensive too. Think it was around 30 grand or so.
Stomper
2017 L2501. Landpride Mower. Farm King Snow Blower. DIY Root Bucket grapple.
Jun 30, 2017
240
Northern Canada
Glad someone posted to this project to pop it up again cause I am in the process of figuring out a design for my build and I have found several good ideas. I really like the double C channel idea
