Finish mowing without a live PTO
Orange man
Kubota L2501 LA525 loader , woods prd6000 mower, Land pride RB 1672
Jul 23, 2014
162
WNY
Looking at a L2502 gear drive, really like it but I would need run a finish mower on it, anyone have a opinion on how bad that is going to be? Have always had live pto tractors.
Elliott in GA
Mar 10, 2021
636
619
North Georgia
FWIW, a Finish mower spins up with very little effort - unlike a rotary cutter. I can start my LP finish 5 foot finish mower at idle speed on the tractor with no bog down, but my rotary cutter requires about 1550 engine RPMs to engage the PTO.
I am not sure that answered your question.
Orange man
Jul 23, 2014
162
WNY
I am more worried about the mower stopping everytime you have to clutch to change direction.
Elliott in GA
Mar 10, 2021
636
619
North Georgia
I doubt it will be much of an issue. It takes some time for my finish mower to spin down, when I turn my PTO off after I have throttled down.
bird dogger
Vendor Member
Feb 24, 2019
1,577
1,427
North Dakota
I ran a finishing mower behind my older JD750 without live rear pto. But the tractor had an overrunning clutch/pto. So if you slowed down to change gears, reverse, etc......as soon as you pushed the tractor clutch in....it would disengage the mower pto. But the mower blades would still keep spinning until they completely slowed down to a stop.
Once you got used to it, you could change gears, reverse direction, etc. pretty smoothly without the mower's speed slowing down much at all. And as soon as you released the clutch again, the mower was back up to speed in no time. Not quite as ideal as a live pto.....but not that terribly bad either.
Orange man
Jul 23, 2014
162
WNY
Thanks, The syncro shuttle works pretty slick on the L2502, so you would be able to shift pretty quick.
jaxs
B1750HST
Jun 22, 2023
459
227
Eventhough the 02 doesn't have live pto like your 01 I don't think you'll see much difference but as bird dogger said,an overrunning clutch between tractor and mower will take care of it if necessary.
Orange man
Jul 23, 2014
162
WNY
Thanks, The tractor has a built in over running clutch
3,505
I mowed for many, many years with a B7200DT and Woods RD7200. Yes the transmission PTO works OK and you quickly learn to wait on the mower when you have to clutch.
Three years ago I bought an L3901 and the live PTO made mowing in tight areas and up against obstacles so much easier I would never go back to a transmission PTO.
JMO and YMMV,
Orange man
Jul 23, 2014
162
WNY
After pricing and looking over the L2502, I will be keeping my L2501 HST!!!!!
