Find TDC on a Kubota D850 engine
cb750k8
B7200HST D 4X4
Aug 23, 2013
101
Dublin, Ireland
Hi all.
I have a D850 engine in a Neuson mini digger and I intend to do Compression and Air pressure tests on three cylinders as described elsewhere on this forum.
Engine runs well but difficult starting in cold weather. In these Covid Virus days I can chase down the starting problem.
Problem is that Neuson have not provided an inspection" timing" port on the bell end of their equipment and I am as a loss as to how to find TDC to carry out the tests.
My current thinking is to take off the sump and go from there.
The front end of the crankshaft has the vbelt pulley with lockwasher, hex nut and splines. I don't know if the flat on the lockwasher could indicate shaft position and have not taken it off to see how it locks.
If anyone has a better and easier way of finding TDC I would be very appreciative.
Thanks
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,135
938
Williamstown Ontario Canada
Remove valve cover.
Watching the action of the intake and exhaust valves should get you to TDC pretty close enough to do your leakage tests.
First intake opens, then intake closes, just before exhaust opens will be TDC.
Dave
3,075
Remove valve cover.
Dave
If you go to all that trouble for goodness’ sake’s MARK YOUR CRANKSHAFT PULLEY for future reference.
