Filtro de aire Kubota B6000
Jesús
Kubota B6000
Jul 15, 2025
36
9
Spain
Hello, good evening. I'm Jesús, in the group, and I'd like to share the problem I'm having. I purchased a Kubota B6000 tractor, and the lower part of the air filter was lost by the previous owner, and now I can't get it back. This filter is oil-bathed, not paper-based, so I don't know how, but I'm without a tractor due to the problem I'm having with the air filter. Does anyone have any used parts to sell or know of a supplier where I can get this filter? I don't care if it's used or new; I need it. Thank you.
2,252
Some of the parts are still available from Kubota so you might be able to have a dealer order them.
This is a salvage yard that may be able to help provide those parts. This is their contact page
Jesús
Kubota B6000
Jul 15, 2025
36
9
Spain
Thank you very much, I have written but they tell me that the part is discontinued, so I have the option of a used part or adapting a new one if possible and someone has done it with a guarantee that it will work well.
2,252
Here are some of the parts that are available (19, 20, 24). The others (21, 22) are obsolete though. I don’t think that our dealers can ship to Spain though! Ask your dealer to check if they can get these individual parts
Jesús
Kubota B6000
Jul 15, 2025
36
9
Spain
The part you indicated isn't in stock. It's frustrating for a filter to be in this condition. That's why I'm writing here to share your group dedicated to this type of machinery. I greatly appreciate your help. I've also found the bucket in Spain, but I'm missing the other parts.
trevoroni
B6000
May 24, 2023
201
250
If you can't find the oil bath cup you could replace the whole assembly with a paper filter.
I've got one with a K&N filter on it.
Measure the intake pipe and find one that fits over it.
I'd get some measurements off of the one I have but I'm not home.
2,252
A good machine shop can make the nut part, someone can cut the gasket. The small cup inside is just a damper to keep the oil from splashing around so could be made out of some plastic cup or bucket with some holes in it. The wing nut and washer are some standard hardware in Europe (probably).
But you might just want to find a filter housing that holds a paper filter from some newer machine and adapt that to your machine.
Good luck with your machine!
Jesús
Kubota B6000
Jul 15, 2025
36
9
Spain
If someone could please show me the measurements of the outer and inner bowl, along with all the components, so I can machine them, I'd greatly appreciate it. A lathe operator can do that work for me. If not, I can adapt an air filter to the measurements the colleague mentioned.
(Mod removed Phone number) PM if you can help
Thank you
Jesús
Kubota B6000
Jul 15, 2025
36
9
Spain
Thank God the bucket has turned up. After a week of searching high and low, it has. The plastic bucket is broken, but there is a replacement, so that's one less thing. Thank you all so much for your great help.
