fel jerky
bmblank
Mar 4, 2015
662
292
Cadillac, MI
I prefer beef jerky on my L3901.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,356
1,781
Western MT
Could be it’s not warmed up, or the RPMs are too low.
4,237
fel jerky on l 3200
Keep RPM around 1800 and see if that helps smooth it out a bit. Flow at WOT makes it harder to control, particularly if you haven’t had a good bit of seat time using the loader.
If that doesn’t help, more specifics would likely lead to better answers.
old and tired
L2800 HST; 2005; R4
The prior models; L2800 and L3400 - early models would get a crack in the 2" hydraulic return hose that would make the FEL be pretty jerky. You might check it to see if a mouse chewed a hose (since new ones were made from a different rubber that did not crack...)
How exactly is it jerky, through out the cycle of raising (or lowering?) or just at the start and/or stop of the raise?
Nicfin36
Jun 19, 2019
1,016
466
Decatur, AL
Why did I think this thread was going to be about how to make jerky with your FEL?
I must be hungry.:ROFLMAO:
