FEL Float Function....
Cobraone
B2650, G1800 FWS, B2782B snow blower, RC48G20 mower deck
Jan 27, 2018
23
Boyne City, Michigan
Absolutely correct, as you know I cold remove the fel completely and if I load the tractor enough by pulling against a large load the front wheels will still come off the ground.
My two cents
MoCo
L6060 Tractor, SVL65 CTL, KX033-4 Excavator
Feb 15, 2021
40
Ontario Canada
Is there any risk of harm to the FEL if a snow pusher is used in Float Mode going forwards? I always regarded Float as something to use when in reverse with a bucket. I assume snow/ice is different? On an irregular gravel driveway like mine using Float would avoid the snow pusher digging in and take advantage of the side skid shoes on the pusher. Thoughts?
5,726
Float is THE position you want/need to be in, so the blade follows the contour of the land. THAT is how snowplow trucks are used, well were, 5 decades ago when I did it..
Just be sure ground/driveway/gavel is frozen.
nbryan
Jan 3, 2019
1,309
831
Hadashville, Manitoba, Canada
use the float not much for forward bucket work, but back dragging using float is really helpful.
My main use for the float is when the front mount blower is on, Drop it into float, and go blow.
