farm diesel
jpark
kubota 3400
Jan 31, 2011
conroe, tx
I am the new owner of a kubota L 3400 I was wanting to know if I can run red aka farm diesel in a new tractor I heard you can't.
B7100
B7100,B7100 with Backhoe and FEL, Goldoni Quad 20
Feb 11, 2010
422
Wales
Never heared that one before! You didn't hear it from a revenue official trying to boost the coffers did you;):D
I doubt they would sell many machines over here if they could not be run on Red,white is nearly twice the price!!
hodge
Nov 19, 2010
2,903
450
Love, VA
I can't answer for your region, but in mine, the farm diesel is ultra low sulfer, and dyed red. The only difference is that it doesn't have a road tax added to it.
I would imagine that your info means that you have to run ultra low sulfer diesel, since it's in a new tractor. As long as your farm diesel is ULSD, then I would think you are fine.
LDB
B 7800 HST
Nov 29, 2010
24
Schaumburg, IL
I was under the impression that all diesels could use the ULSD, and that the problems were with newer engines running older formulations of fuel. It is also my understanding that the problems were not with the engines themselves, but the exhaust after treatment systems installed on "on road" diesels.
Disclaimer: I have been wrong before.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
78
Rocky Face, Georgia
Most fuel distributers just die the ULSD and say that it's high sulfer. The reason being is they can't risk taking a load of good fuel to a place that could sell it for on road fuel. Any off road equipment should be fine to burn red fuel tractors included.
steve l
2 m9000,9540 all cabgmd700 kuhn 605m vermeer,r23a vermeer rake,468 jd baler,
Dec 29, 2010
77
bullard,texas 75757
red fuel runs just fine in my dodge truck(only if i get low LOL).all our tractors run on red diesel and rotella oil.
Kubota Newbie
Dec 28, 2010
533
81
Mount Vernon, Ohio
Hodge and Bulldog are right,
The dye is simply used as an identifier so highway officials can tell if you're paying the required highway taxes. There used to be a physical difference in the fuels but nowadays it's usually all the same stuff (except the farm fuel isn't taxed as heavily). An additive to improve lubricity might not be a bad idea in older engines originally designed to run on a fuel that contained more sulfur. RC
KubotaTech
None- I get to play with everyone elses stuff
Apr 1, 2010
185
PA
Red diesel is high sulfur 50 PPM or more
Low sulfur is 15-50 PPM of sulfur
Ultra low is less than 15 PPM of sulfur
Red is untaxed off road and not recommended in tractors that are serviced with the latest API certified oils because the new oil does not have additives to break down the high sulfur content. These oils are formulated for new tractors running on low sulfur or ultra low sulfur fuels.
Wxman
MX4700HST/loader
Feb 1, 2011
32
Indiana
Color has nothing to do with the sulfur content. As mentioned, just a dye for tax purposes.
I believe, this argument is pretty much moot as of June 2010. In June 2010 the EPA mandate limited sulfur content of diesel to 15 ppm, for both on-road and off-road, amber or red. The only exception was NRLM, non road locomotive or marine diesel, which is allowed 500ppm sulfur until sometime in 2012. Most of us wouldn't have access to NRLM fuel which means we are using 15ppm max sulfur, ULSD, whether red or amber. NRLM is not the red, off-road, farm use diesel most of us are familiar with.
It is interesting to note the pump lableling requirements did not keep up with the EPA mandates. There are pumps here in IN that still read high sulfur greater than 500ppm, but it is 15ppm max sulfur because that is all the retailer can buy from the refiner. Don't trust the pump, talk to the supplier if it is important to you.
Wxman
