Factory rear hydraulic connector
sg5054
L2250
Nov 3, 2016
21
Dresden, ME
I've searched the threads and found plenty of discussion for setting up rear hydraulics. This connector from K is mentioned (p/n 99063-93100) (wrong p/n should be 99063-933000 and sells for about $300. I've searched the net and have yet to see an actual picture of one. Has any out there seen one or is a mythical part?
Scott
5,167
I've searched the threads and found plenty of discussion for setting up rear hydraulics. This connector from K is mentioned (p/n 99063-93100) and sells for about $300. I've searched the net and have yet to see an actual picture of one. Has any out there seen one or is a mythical part?
Scott
HAHAHA :p $300, Try more like $1000, and that's if they were even available, they aren't, and used ones are incredibly rare!
Do yourself a favor and go to surplus center and set yourself a 2 or 3 spool open center valve with power beyond.
sg5054
L2250
Nov 3, 2016
21
Dresden, ME
Your right, I'm wrong. P/N should be 99063-93300 not 93100.
It's a small metal block that goes under the speed control knob to supply the oil and the return to the 93100 valve.
My bad.
Kubota: BLOCK,HYD.OUTLET
Part Number 99063-93300
Messick's Price $356.35
Stock Quantity 0
Weight 1.10 lbs
BLOCK,HYD.OUTLET
5,167
Yea sadly that part will not be available either.
There is far easier and cheaper ways to tie into the hydraulics.
If you tell me exactly what model tractor you have and what you want to accomplish I can help you out with that.
sg5054
L2250
Nov 3, 2016
21
Dresden, ME
Thanks wolfman. It's an L2250DT. I want to have a hyd toplink.
The block can be had but boy are they proud of it.
I did find a guy on ebay that has 31351-38310, the cap that the block would replace so there would be a pattern to make one.
