I have owned the F-2400 one month.
These are the symptoms, not charging, oil/temp lights dark, engine will not stop with key.
While running, the battery is at 12.3 volts, alternator output is 15.5 volts.
Fuses in main fuse block OK.
I just called a local Kubota service center & they said it was the main fuse (50amp) on the starter side of the engine. I can not fine this inline fuse.
Any help would be very much appreciated. Thanks Laddie.
