F-2400 ELECTRICAL PROBLEM
Laddie2
F-2400
Jun 20, 2021
30
I have owned the F-2400 one month.
These are the symptoms, not charging, oil/temp lights dark, engine will not stop with key.
While running, the battery is at 12.3 volts, alternator output is 15.5 volts.
Fuses in main fuse block OK.
I just called a local Kubota service center & they said it was the main fuse (50amp) on the starter side of the engine. I can not fine this inline fuse.
Any help would be very much appreciated. Thanks Laddie.
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,140
139
Hardisty, Alberta
It is a fusible link. It looks like a length of wire but is designed to burn out if overloaded. I usually replace them with a circuit breaker.
Laddie2
F-2400
Jun 20, 2021
30
I do not see a fusible link. The fusible link on the battery I installed for led lighting.
eserv
May 27, 2009
2,140
139
Hardisty, Alberta
The red wire in the picture of the starter is probably a fusible link. the picture doesn't include enough to see the other end of the wire.
Laddie2
F-2400
Jun 20, 2021
30
I will look again & take photos.
There is no fusible link near the engine only connectors which have continuity.
The 15 amp fuse while not blown has no power on either side.
There must be either an open fusible link or a break in the wire going from the starter to the 15 amp fuse. I will try to open the harness or run a new fused wire.
I HATE ELECTRICAL PROBLEMS!
