error code PO336, MX5200 tractor
WisconsinPat
MX5200
Jul 21, 2015
Trempealeau, WI, USA
This error code came on yesterday when a friend was using my tractor. I used it today, and it seemed to run fine, but the error code flashes alternately with the hours. Is anyone familiar with this code, or know where to find a list of Kubota error codes? My owner's manual gives a few, but they all start with E, not P.
Shadow
190
Somewhere
Crank position sensor abnormality. The fault code resets with the keyswitch, but the code will still show until you clear it on the dash. With the key off, hold both the inhibit regen switch, and the parked regen switch. Then, while still holding the switches, turn the key on. On the dash will flash "a". Hit the parked regen switch again to toggle to the "b" option. Hold the regen switch until it says "off". Turn off the key, and it should be cleared. If you stall the tractor, its not uncommon to see this error code occur
