bcbull378
GL3830,fel,brush hog,pallet forks,disc,gannon,auger,springtooth,plow,drag,ripper
I went out today looking at new equipment trailers, cant seam to find a good used one. Things are very exspensive these days $5400 for the one that looks like itll move most anything I can pull safely with my truck. The trailer is good for 14000 lbs double axel and brakes on both ( 7000lbs ) axels, most people worry about running down the highway at 50 mph I worry about stopping the thing. I believe between the double axel brakes and the exsaust brake on my F350 I should be ok. The trailer is good for much more than Ill be hauling but I always error on the safe side. Ill still look for a used unit till march then its time to bite the bullet. So with that being said what do you fellas and ladies move your equipment with?
