Enough cca
al m
Kubota b1750,60" mm,48" argo trend snowblower,5' grader blade
Jul 30, 2012
258
smiths falls on Canada
My b1750 is rolling very slow with the recent cold snap,not enough to start it today,In fact It hardly rolls. It will only fit a small battery,one in it is rated at 425 cca,and the best I can find tops out at 500cca.is this adaquate in well below freezing temp to glow then roll a d950 engine?
2,233
It should be - keep a tender on it when not in use, that extra umph is the difference between a fully charged battery and a almost full battery.
Charge the new battery too. Most batteries will lose a little zip sitting on the shelf;)
