hello again fellow users, i need one more time help.
i have a l501dt and i have fix almost everything on it,
i have change the head gasket, add temp gauge, watched then the cylinders and they was good for my knowledge, i have adjust the valves, clean the radiator in and out , change the cup, change the gear oil because it was black and some times the gear was grinding, clean the valve there under the seat and the filter, now they work perfect.
now i have one other question,
the tractor starts very good even at 0 Celsius and it runs great. but i see a puff of black smoke even if the engine is hot when i suddenly press the petal from low rpms to high, or when i start in 4H gear with very low rpms,
is this normal?
i can cruise around at 1300rpms and press the pedal for a moment until 2500rpms and it puffs black smoke and then clears.
some times this smoke looks gray near the exhaust and blacks when is over the sky..
sorry for my explanation.
i have change the diesel filter 20hours ago but the air filter is old, so i have cleaned with pressurized air.
tomorrow i will put a small video for help.
is my tractor dying? or i worry to much ???
is this normal?
