Engine Knock M4500DT
Fishfarmer
Kubota tractor M4500DT Kubota excavator KX161-3
Aug 8, 2021
114
I have an M4500 with the same engine S-2600A and it has 2400 hrs on it. I have had it for several years and put on about 200 trouble free hours. When did you notice this "knock"?
If the rod is knocking, its frequency will increase with rpm. Is that the case?
The puff of smoke when you rev the engine is just excess fuel that isn't burned as the engine speeds up.
Can you tell what cylinder the knock is on? If you can, then switch the injector from that cylinder to the farthest one away from it and see if the knock follows the injector. If it does, you have found your problem.
Jim I am going to try what you said and swap injectors this weekend. I understand if the noise follows it then it is the injector. If the noise doesn't move could it still be the injector pump timing causing the nailing? Or do I then check if its caused by play in the big end bearing?
JerryMT
Jun 17, 2017
529
154
The Palouse - North Idaho
If the knock doesn't follow an injector, I would do a compression test. A leaking injector can cause a burn through of a piston crown, or you might have a burned valve that's making that cylinder a dead one.
Fishfarmer
Aug 8, 2021
114
Put tractor together after all the tests run it doing “Brush Hogging”, what we call “Slashing” in Oz. Knock is still present especially idling, can’t hear it under load.
Injectors popped okay and sprayed well, One a little bit uneven. IP seems to spurt evenly. Oil lamp flickering on and off at idle after it got to hot running temp. Manual says this is okay, idle 7.11 psi and running 42.7-64 psi and allowable limit 35psi. I put an oil pressure gauge on it and when cold runs at 60-64psi, then as it gets hot drops to 50, then 40, then down to 20psi when fully hot. It idles at 10psi. if I hit the revs full for a couple of seconds it goes to 30 and for a short burst hits 40 psi. Manual says at rated speed. All I can see the speed is in a different section as “Maximum bare speed” 2800rpm.
There are no silver flecks in the oil. It doesn’t burn oil, hit high revs under load or no load there is a puff of grey, or sometimes black and grey. I did a piston push down test and there was zero movement. JohnDB suggested that he thinks there would only be movement when the lower piston rod bearing was really bad. Spun bearing with a lot of clearance. I tend to agree with him, therefore it’s a poor test for a very worn but not quite (yet) ruined bearing. Please correct me if I am wrong but the point I am making is I still think the knock is from the bad piston that has the lower compression and not an injector(see my other posts). For the oil pressure to go so low when hot would indicate to me that oil is losing pressure past the bearings and causing rod knock on the bad one.
4,196
If the “knock” occurs only after initial start-up…and stops after increasing RPM…it’s likely OIL PRESSURE problem or indication (or lack thereof). CHECK OIL PRESSURE.
Fishfarmer
Aug 8, 2021
114
My error of grammar. The lack of oil pressure is not causing the rod knock, the worn bearing is causing the knock and the low oil pressure is the sign of that's what the problem is. ( thinner oil getting past the side of the bearings instead of being forced through the oil passages in the journal. Geohorn the knock is there on startup when i have 60psi oil pressure ( not just initial startup) It goes away or at least I cant hear it under load or revs, yet when I decelerate you can hear it most as it slows to idle, more so after its hot slowing to idle. I am not an experienced mechanic but people have said rod knock is heard more when the load is off the problem piston and the knocking is more pronounced because it is free floating and slapping the journal at TDC. When the pressure is on from combustion it is hard against the journal and harder to hear, although still probably there. At least that's the explanation I have always been given.
The oil pressure, is what it is. The pump must be working fine to push out 60psi when its cold and it should push out 40psi when its hot. I wouldn't think it is oil pump related for it to suddenly perform so poorly at a higher operating temperature, rather it would seem to me to be worn bearing related. So to check the oil pressure you suggest, I can only see by stripping it down could rectify this. Is this what you mean? I am using 14w 40 oil but I read that a heavier grade oil (20W-50 or 50W) can help raise oil pressure and maintain the protective oil film between the bearings and their journals ? Thanks for your input.
4,196
If you confirm you have 40 psi of oil pressure or greater… then the knock I was thinking-of…(valvetrain related) will not be the problem.
The viscosity of the oil you choose to use is not the problem and changing oil viscosity or brand is not going to solve it either.
It’s difficult to diagnose serious/deep engine problems over the internet...so it’s time for you to have an experienced diesel mechanic/technician look at it, IMO. The problem will not go away on its’ own and continuing operations will only add to the possibility of serious damage.
JerryMT
Jun 17, 2017
529
154
The oil pressure, is what it is. The pump must be working fine to push out 60psi when its cold and it should push out 40psi when its hot. I wouldn't think it is oil pump related for it to suddenly perform so poorly at a higher operating temperature, rather it would seem to me to be worn bearing related. So to check the oil pressure you suggest, I can only see by stripping it down could rectify this. Is this what you mean? I am using 14w 40 oil but I read that a heavier grade oil (20W-50 or 50W) can help raise oil pressure and maintain the protective oil film between the bearing and their journals ? Thanks for your input.
You might want to get an oil sample analyzed. If you have a bearing going south it will surely show up in the oil analysis. All the guessing and theorizing what it might be won't get you to an answer. Take some action. Analyze the oil or pull the pan and check the journals.
kubotafreak
Sep 20, 2018
1,049
402
Arkansas, US
If there is no discernable metal in the oil, then it is more than likely the lower end is fine. The knocking could be piston slap (hard to physically test due to the need to rock the top and bottom side of piston crown). Wrist pin loose, or other piston deformity. The posted oil pressures seem on the loose side though. The 20 at rated speed is way too low (35lbs min). Did you crack injectors loose one at a time to locate the cylinder causing the noise? I think I would pull the timing cover and inspect the pump. Also check the orings/plugs behind the timing cover. What was the compression?
sanjeevtyagi
M4500DT
Mar 6, 2023
37
Oregon
I have noticed a knock in the engine on my M4500DT. This is my first tractor which I havent had for long and not used to its sounds. I have a small diesel tipper and Kubota excavator which are quieter but have the usual diesel tappet sound. The tractor has a noisy valve train sound which I thought was normal being open and from what I read about this old model. However this sound I notice is different like "Rod Knock". I have heard this type of knock in gasoline cars during my lifetime, so this worries me that its the same. I am not familiar with any injector knock timing sounds and doesnt sound like piston slap because it doesnt go away. It only blows a tiny bit of white smoke on reving and the knock is not any louder with revs, but you can hear it more clearly on idle and cold or warm is the same. There is some blow back. I realize no one can diagnose sounds over the internet. I will get a mechanic in to diagnose but does anyone know if this model can be checked with the injectors removed and putting a rod down and hand turning crank past TDC and feel for downward piston play? I see on gas cars they remove spark plugs to check with this method. I also thought an oil pressure guage but it may not give the correct diagnosis. If it were a car or truck I could drop the pan and check the journals but on the tractor this doesnt seem possible. The tractor is built around the engine and appears to be a huge job just to check the bottom end. I can take the head off but once i start it may as well be a rebuild which I dont want to do. Any advice to positively identify the knock is appreciated?
I have M4500DT i acquired it for about 8K with Loader and Tiller , it was starting with starting smoke and a good amount of blowby i was told it would need piston6 rings , so i went ahead and did oil changes , filters and anything it required (Still to do GP and INjectors) but after i put in 15W40 it doesnt want to start it smokes a lot and then cranks a rolls over but doesnt want to start , the battery loses juice after some time , could it be that 15W40 is too thick for it to start ? Any inputs from your side is appreciated.
11,015
You could try switching to 5W-30
But really you need a rebuild!
sanjeevtyagi
M4500DT
Mar 6, 2023
37
Oregon
It starts right off nowadays , it still smokes from breather tube but much less , it was a problem combination of glow plugs being old and starter going bad , i did replace all the 6 glow plugs and a new starter and it just starts right off smokes but still runs good and does the job
