Engaging PTO on b2320
Jtryan
B2320
Jan 17, 2016
55
Ottawa, Ontario Canada
Sometimes when I try to engage mid pto for mowing the lever doesn't seem to want to pop in place! So then I move the lever to rear pto and it pops in.... move tractor slightly and then try to put lever in mid pto again and it pops in place!
So my question is..... is this normal that it happens from time to time!?
I think the linkage for engaging pto is mechanical and not electronic so maybe that plays a roll!?
Missouribound
Jun 17, 2014
646
38
Missouri
I have a B2320 and haven't experienced that problem.
I also have to ask.....you ARE using the clutch......right?
MadMax31
BX23S, 60" MMM
Nov 5, 2014
766
New York
When I engage my mid PTO, often, I have to "double clutch" to get the lever to notch into place, then feather clutch out. I always lower RPM before engaging or disengaging either PTO.
Sorta related, this is why I love the HST. While hogging, if I run into thick stuff or rocks I can just back off pedal and and lift 3pt or just reverse out.
Tooljunkie
May 13, 2014
4,150
31
It sometimes needs to turn a little to help mesh the gears. My L1501 has a similar issue, unless trans is in neutral then pto engages most every time.
