Electrical damage caused by rodent 2004 Kubota B7610
3,418
Kubota does not use that type of wire, its was mostly found in the automotive industry but not limited obviously
Maybe they do, maybe they don't.
But if it were me I would just repair the problem rather than spend lots of money putting a new harness in that could end up with the same issue...Just me perhaps?
whitetiger
Nov 20, 2011
3,824
2,225
Kansas City, KS
Kubota did in the past use soy-based insulation on the wiring harness.
RBsingl
Kubota F 2690 72" rear discharge deck, Deere 955
Jul 1, 2022
488
573
Central IL
It would be extremely difficult for Kubota to have avoided soy compound insulation because it is so embedded in the supply chain. And because absence of soy or peanut oil doesn't ensure that rodents won't attack wire, there was no reason for them to do so.
Rodents gnaw on wire regardless of the insulation compound. I have restored vintage ham radios from the 30s through the 60s and some of each decade had rodent damaged wiring, long before non-petroleum insulation was used.
Rodger
dvcochran
Kubota M9000, New Holland TN90, Deere 2640, Vermeer 504N, Vermeer 504SI, more
Feb 23, 2011
219
47
Dickson, TN
Good Afternoon
Rodents have gotten behind my dash board and chewed several wires. Does anyone know if I can replace the plug or will I need an entire harness?
The spades easily remove from the plug with a connector tool or very small screwdriver. Assuming length is not an issue, very carefully and accurately mark the location of all the wires, cut back to good wires all the same length, crimp new spades and click them into the connector. You should be good. Spades are cheap and the way tractors bounce around I would be concerned with solder and heat shrink.
***COMMON SENSE CAUTION*** Do Not get any wires out of place in the connector. If you do not feel confident doing the wires all at once, cut and spade them one at a time. Harder, but easier to be accurate.
