ECU Error Code P0606
MBoyle
Kubota L3301, with LA525 bucket, an 5' Land Pride Bush Hog
May 5, 2025
Alabama
I'm new, tried searching for code P0606 here but I must've done something wrong cause I got zero returns. Anyway, I cleaned the battery connections and put a charger on it on set to crank power. Code remains. I would appreciate any help.
Tractor is a 2015 L3301 HST.
ruger1980
L4310 w/La682, L225
Oct 25, 2020
590
255
CNY
whitetiger
Nov 20, 2011
3,753
2,167
Kansas City, KS
You need to contact your dealer about this TSB.
TSB-2023-035-E-R3
Warranty for 8 Years from retail date
Issue:
The engine may fail to start, and DTC code P0605 or P0606 may appear.
Solution: If DTC P0605 is present, replace the engine ECU with the updated engine ECU in the chart per the Workshop Manual and complete a manual DPF regeneration per the Diagnosis Manual.
If only DTC P0606 is present, update the ECU Software to the latest software per the chart for your unit and clear the DTC codes (The DPK file can be downloaded from the Machine Software page on K Service).
