Early 80's L285
ry-guy113
L285, L210, woods RM660
Nov 30, 2022
anybody know how to distinguish the model year of these tractors? I think I'm going to need to replace my starter.
bucktail
Jun 13, 2016
1,251
189
MN
You don't need the year, you need the serial number. If there is a change to the starter it will be at a certain serial number not a certain year. Often the new one supersedes the old one.
Roadworthy
L2501 HST
Aug 17, 2019
1,649
526
Benton City, WA
If you're sure you need a starter you should be able to take it to a local starter repair shop. They can probably either repair yours or come up with an equivalent replacement for far less than the genuine Kubota article which is unlikely to be made by Kubota anyhow.
1,418
See this thread for information on starters
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,236
1,018
Williamstown Ontario Canada
It might be prudent to share the reasons/ tests done which is leading you to this conclusions.
It might be something simple like rust between the starter body and the engine block which is providing a poor ground path for starter current.
If you have any knowledge of using a multi meter you can be provided a simple series of voltage drop tests which can zero in on the problem.
Dave
