Driveway - big mess!!!!
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
77
Rocky Face, Georgia
Aside from asphault or concrete nothing is going to help without dealing with the water first. As long as the water is running down the middle it's going to wash away.
m32825
L3800HST
Jul 12, 2013
215
25
Central FL
have the load blended rock/fines and cement. after smoothing, water it down or hope for a light rain… you will end up with a hard surface, with enough grip to keep from spinning your tires in adverse weather...
If you had your rock like you wanted it, do you think could you dust it with a heavy coat of dry cement and then lightly water it in to hold it in place?
-- Carl
bosshogg
2004 L3400F w/ FEL
Aug 16, 2012
231
Hartford, SD, USA
Unless you really do an engineered job, you will continue to have to do maintenance.
The first thing that is required for a fixed job is keeping the water off the road with a change of cross slope and install collecting culverts. The hill side of the road then will be lower that the outboard where a ditch is dug at the hill side. The spaced culverts will take away heavy flows before the ditch gets so loaded that that is eroded. Ditch probably needs paving with rip-rap placed on geotech fabric.
Farther up hill, diversion ditches will help reduce the flows that you have to handle.
So a real fix takes a lot of work and expense.
Chip seal or blacktop paving will not solve things, unless water flow over the surface is controlled, especially at the edges. Fixing washed out paving is more of a job than as now present.
As in engineer with 30+ years experience...you are exactly correct.
