I have a 55 gallon plastic barrel and want to install a drain valve on the side of the barrel near the bottom. I don’t want to cut the top off the barrel. Most of the valves I have seen require the top to be removed in order to install the gasket and nut on the back side of the valve. I have seen some cheap plastic valves that don’t require this, but the ratings aren’t that good – leak, come loose, break…
Does anyone know of a valve that I can use? Maybe something with a compression connection???
This will be used indoors so I want something of good quality that won’t leak.
I am also looking for a valve that I can connect a garden hose to.
